Linux and Powerbook (plus mouse buttons) question
Man of Honour
19 Oct 2002
Surrey
With all the Mac lovers seemingly wanting to get a MacBook (and who can blame them they look lovey!) it occured ot me that there may be some cheap used Powerbooks floating around. But rather than run OSX on it I was toying with the idea of putting Linux on it instead (probably Ubuntu which I can't seem to fault nowadays). If I were ot do that I'd still be stuck with the single mousebutton issue. So is there a way of simulating the second mouse button in Linux in a similar way to OSX accepting CTRL + Click for the RMB?
I thought I'd get that answer :). I've got several machines:
A desktop running Windows and Linux
Several laptops running Windows and Linux
A Powermac running OSX
Of those I use Linux the most. But I fancy the looks of the Powerbook.
I was messing around with the latest kernel release (2.6.17) and found this in:
Code:
Device Drivers  --->
     USB support  --->
[*]   HID input layer support
[ ]     Enable support for iBook/PowerBook special keys
Code:
CONFIG_USB_HIDINPUT_POWERBOOK:        x
  x        x
  x Say Y here if you want support for the special keys (Fn, Numlock) on                                                      x
  x Apple iBooks and PowerBooks.
Hopefully of some use, though I don't have a MacTop, yet ... :)
Also in 2.6.17 is support for Airport Extreme Wireless cards.
As for Macintosh kit running linux, well if its good enough for Linus Torvalds.... ;)
p.s. Linux runs faster on the same Mac hardware than OS X does, though this is mainly due to the overhead of using a microkernel and OS X's rather crappy memory management.
