linux + flash = FAIL
29 Jul 2003
hi guys
every linux distro i tried, any websites with small flash always make my laptop CPU very very ill :(
ubuntu, linux mint, fedora 10 and PClinuxOS does that on FF and opera.
but on xp, it's perfect.
why?
Flash isn't really accelerated on any platform.
As for why it sucks, Adobe can't code.
Your best solution is to enable the CPU scaling applet and clamp your CPU frequency to about 50% instead of using the usual on-demand CPU scaler. Flash will still work but it won't peg your fans out all the time.
rock XCT 2.0ghz, 1gb ram, nvidia 7800GTX
the whole point is flash is running perfectly on xp, no matter which broswer i use
Humm are you using 32bit or 64bit linux? 64bit flash is shockingly bad! (never worked for me) but 32bit does work resonably well(ish).
What CPU? 2.0GHz means nothing these days.
The basic reason I suspect is because Flash is not open source. This means the only people working on a Linux version are a small group at Adobe. And TBH, they're either idiots or there's like three of them.
My experience with flash on linux is also bad. Straight when I hit a flash page my cpu goes up and after maybe 15mins the fans start to go. Every update to flash seems to make the performance worse.
One thing I do is install flash block plugin for FF, you can allow all the sites you want flash to appear on eg youtube iplayer etc, while any other websites with flash ads etc are not run, saves a bit of your resources.
