linux htpc and nas at same time
4 Mar 2016
Glasgow, Scotland
linux htpc and nas at same time. I would like to have two pc but i can not afford it. so is it to have a nas and htpc on the same pc.
the spcs would be
intel pentium g3258
GIGABYTE 1150 H81M-H
HyperX FURY Series 8GB
Samsung SH-224FB/RSMS 24X Internal DVD
Seagate ST1000DM003
Seasonic 300W 80+ Bronze
Silverstone
SST-ML04B
Thanks Joshua
Quite simple to do.
If it was me doing it, Ubuntu desktop install to cover the HTPC side of it and then install mdadm to create a RAID array for the NAS side of it, samba to share over the network and you're good to go.
My htpc in the front room has ubuntu with xbmc as the frontend, large storage capacity which is shared via samba, easy peasy.
easiest way install openelec (can run off 2gb ram or less), will play his media and can act as a nas, enable samba when installing, wouldn't bother about raid just have media backed up to another 3.5 disk
Yep, definitely doable and works fine, I had that setup for ~2 years until I got annoyed with the noise (and moved house) so split it into two machines, one with many spinny drives and the other being entirely passive.
As we're in the linux thread and all.
What about having your setup in the OP as your media server and then buy either a nowtv and sideload plex for your HTPC side of things (£15) or alternatively a raspberry pi running openelec (£50 with a psu, SD card and case)?
I wouldn't want my home server next to my TV with the noise it makes
