- 28 Jun 2005
I program I need won't work unless it has an old version of a library available to it.
error while loading shared libraries: libstdc++-libc6.1-2.so.3: cannot open shared object file: No such file or directory
I can't find that particular file anywhere on the net, but I can find compat libraries that supposedly contain it.
e.g.
compat-libstdc++-rh71-1.i386.rpm
When I install that using :
[root@mybox]# rpm --install compat-libstdc++-rh71-1.i386.rpm
package compat-libstdc++-rh71-1 is already installed
[root@mybox]# rpm -qa | grep libstd
libstdc++-3.4.3-9.EL4
compat-libstdc++-33-3.2.3-61
Can I just link the compat entry to point at libstdc++-libc6.1-2.so.3 or am I way off?
e.g.
