Linux mint 14 screen issue
30 Nov 2011
Hi,
As of now when watching a flash video in youtube the screen goes off after about 10mins..
Googling gave me these 2 commands that solve the problem.
For a temporary solution (at least for the time you are logged in) you can run the following 2 commands in the terminal:
Code: Select all
xset -dpms
Code: Select all
xset s off
If you put them in a script saved as a hidden file in your /home directory, you can add it to your startup applications to do it automatically each time you boot.
Question is, How? How do i put those 2 commands in a a script?
Thanks,
Sean
