Hi,
Trying to setup an XP/Ubuntu dual boot machine.
Machine has two HD's (40 gig and 20gig). XP went on first on the 40 gig and then Ubuntu on the 20 gig.
When I boot up GRUB tries to load but then I get error code 25. I think this means something is wrong with the boot record or it could be a motherboard problem.
I got SuperGRUB off the web. Which is a CD that allows me to boot both OS's but I would like to try and fix this problem.
One thing I am a little bit worried about is that I think both HDD's came up as slave when I was installing Ubuntu, could this be a problem?
Any help appreciated,
aaazza
aaazza
. Its still a viable option if you can get into Ubuntu tho, you can boot from the live cd and mount the linux partitions to edit the device map.
