Linux on Netbook...
14 Oct 2007
I have Linux on my Netbook (Advent 4211) but it won't pick up Wireless drivers and I know NOTHING about Linux, can someone please help?
Did it but nothing happened, just got this:
kencs@kencs-netbook:~$ lspci | grep network
and nothing happened...
Nevermind, me being retarded lol...
Getting results now...
^^ capital N in network
So I open up Terminal and type lspci | grep network and thats it?
That's just part one of many :) Linux very rarely offers you one step solutions im afraid :(
lspci | grep Network will tell you the make/model of the wireless card in the netbook. Post that information here and then you can get the correct wireless drivers.
I just typed lspci and got the following:
00:00.0 Host bridge: Intel Corporation Mobile 945GME Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GME Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 02)
00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA AHCI Controller (rev 02)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 02)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 02)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8187SE Wireless LAN Controller (rev 22)
Ok cool, so this is the important line:
Are you on Ubuntu? Assuming you are that card is support out of the box. So in a terminal:
sudo apt-get install wireless-tools
Then run "ifconfig -a" and see if you see a wireless device in the output might be called wlan0 or ra0 or similar (not eth0). If thats there then you're good to go and can just use the gnome network manager in the system tray to connect to a network
If there is no wireless device shown in ifconfig, try running "modprobe rtl8139" then post the output of lsmod | grep rtl8139 here and recheck ifconfig -a.
this may make more sense to u there:
ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:21:85:53:b7:27
inet addr:192.168.1.14 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::221:85ff:fe53:b727/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:990 errors:0 dropped:0 overruns:0 frame:0
TX packets:974 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:570174 (570.1 KB) TX bytes:166333 (166.3 KB)
Interrupt:42 Base address:0x6000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:216 errors:0 dropped:0 overruns:0 frame:0
TX packets:216 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:16848 (16.8 KB) TX bytes:16848 (16.8 KB)
wlan0 Link encap:Ethernet HWaddr 00:21:85:7b:12:ed
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:17 Memory:f8060000-f8060100
Ok good :) so wlan0 means that your wifi is detected and up and running :)
So you should just be able to use it now i.e connect to a network.
This may make more sense to you :)
When I click on the networks icon after disconnecting my network cable I have:
Wired Networks:
Disconnected
Wireless Networks:
Disconnected
VPN Connections >
Connect to a hidden Wireless Network...
Create New Wireless Network...
It doesnt even show networks in range...
MMMMmmmmm might sound simple but...
have you switched your wireless connection on?
I mean with the dedicated button or keyboard combo?
It's easily overlooked... had my wife cussing about it the over weekend and I just walked up and pushed her wireless button and walked away with a smug smile ....:)
Belay that... it would be showing
Wireless Networks
wireless is disabled
if it was switched off :(
try a reboot :)
