- 7 Mar 2005
- LU7
Hi all. Very rarely venture in 'ere.
I've got some spare components that I will be turning into a spare PC and I'd like to run Linux on that. I was thinking of Ubuntu. However I've now moved home after finishing Uni and I'd like to be able to watch TV in my room as Mum has the TV a lot of the time.
So we'd be getting a 2nd Virgin Media box. What I would like to know from you lot is what Linux build could you recommend to run on a spare PC to enable me to watch TV through a TV card?
Also can anyone suggest any fairly cheap TV cards with good Linux drivers/support. I don't need anything fancy, just something to allow me to connect the VM box to the TV card and then output the display onto my LG 17 inch VGA screen.
If it helps this is the thread from the Hi-fi forum. http://forums.overclockers.co.uk/showthread.php?t=17883083
