Linux shell command help needed - file path length
Man of Honour
18 Oct 2002
Northallerton/Harrogate
Hi,
I need to list the contents of a folder structure, including the length of the total path for each file in # of characters.
Is this possible?
I'm not too hot with linux.
find -name "*.wr" -print doesn't really do what i need.
It's just the length of the whole folder structure for each file I need.
Or even better, just list those files which are above a certain length, e.g. 60 chars..
Any ideas?
Code:
for i in `find -name "*.wr"`; do echo -en "$i\t"; echo $i | wc -c; done
will show the filenames and filename lengths.
Code:
for i in `find -name "*.wr"`; do if [ `echo $i | wc -c` -ge 60 ]; then echo $i; fi; done
will display filenames of 60+ characters.
THIS:
Code:
#!/bin/bash
for f in $(ls -b /home/user/ ); do
 length=`echo $f | wc -c`
if [ $length -gt 60 ]; then
        echo $f ; echo $f | wc -c
fi
done
but I don't know why it doesn't work.....
edit - ahh must use -gt and not > now it works. edit as required :)
