Linux terminal command to clean a base64_decode hack?
21 Oct 2008
Mooching... in your house
We have had 3 sites hacked, they are all the **base64** encode hack that looks like this:
Code:
eval(base64_decode("CmVycm9yX3JlcG9ydGluZygwKTsKJHFhenBsbT1oZWFkZ.........")
Is there a command similar to this one:
Code:
$ find . -name "*.php" -print | xargs sed -i 's@eval(base64_decode("CmVycm9yX3Jlc........")
That I can use but which uses Regex to find and replace the entire string based on the starting characters? The reason I ask is because every instance of the injection starts the same but concludes in different ways, so I'd like a way to attack all of them at once.
Any ideas?
It doesn't have to run all the way to the end of the line, I've just tried the following command and it removed the eval() bit but left everything else on the line.
Code:
find . -name "*.php" -print | xargs sed -i 's@eval(base64_decode("CmVycm9yX3Jlc.*")@@g'
