Lion and CS4 compatibility
6 Jan 2009
Hi all,
Is anybody else having problems with CS4, post upgrading to Lion?
I don't use it very often, however Illustrator seems OK, but when I launch Dreamweaver it crashes on launch.
Any thoughts? I've submitted the crash report to Adobe, and can't seem to find anything specific on the forums. I'm guessing it needs an update from Adobe?!
Cheers,
Grant
I have CS4 installed at the moment on a MBA 2011 model with Lion and it works perfect that I can tell. Lion was Pre-installed, however when I reloaded Lion it worked fine. Will be moving to CS5 shortly.
PS not sure about dreamweaver as that's not installed just Photoshop.
There may be updates to get after it's installed.
Possibly, but they don't mention the issue you are having on their Lion page...
http://kb2.adobe.com/cps/905/cpsid_90508.html
Have you tried deleting Dreamweaver's preferences? They are located in the following folder...
Code:
~/Library/Application Support/Adobe/Dreamweaver
Although it's for CS5, you could try some of the suggestions here...
http://kb2.adobe.com/cps/832/cpsid_83223.html
Thanks I'll take a look at the suggestions. Regarding updates, I've already ran the Adobe update which found no updates for dreamweaver :(
