Liquid cooler vs air cooler
22 Oct 2019
I am thinking of getting a new cooler for my cpu and these are the two I have narrowed it down to:
Cooler Master ML120L RGB AIO cooler
Or
Raijintek Leto Pro RGB air cooler
I know that there are a lot better coolers out there but I am only after a budget cpu cooler for my sons first pc build.
Specs. are:
B450 gaming pro carbon mobo
Gtx 1050ti gpu
Ryzen 5 2600x cpu
Which one would be the best to get for performance or if anyone could reccomend a different one for roughly the same budget £40-£50.....cheers
I'm not sure I'd bother with liquid cooling. It's not a hard chip to cool, you're not going to get massive clocks out of it. Air will be cheaper, as quiet if not quieter, more reliable and cool perfectly well.
arctic freezer II 240 is cheaper, quieter and cools better than air from the reviews I've seen. reliability is unknown at this point.
OcUK has Matterhorn White B Grade for £34.99
https://forums.overclockers.co.uk/threads/liquid-cooler-vs-air-cooler.18868884/
and Matterhorn Blac B Grade for £26.99
https://www.overclockers.co.uk/b-grade-alpenfoehn-matterhorn-black-cpu-cooler-bg-016-al.html
Both are 158mm tall so check your case CPU clearance is 158mm or more.
I suggest calling or emailing OcUK to be sure they have AM4 mount. Alpenfohn website says they come with AM4. OcUK website does not show AM4 mount but I'm guessing they just haven't updated website.
