- 25 Nov 2014
- Earth and soon Heaven
So I got this build for my son its his first gaming PC
The cooling for the CPU is just a simple fan type thing but I wanted to put something better in like one of these
https://www.overclockers.co.uk/antec-mercury-240mm-rgb-aio-liquid-cpu-cooler-hs-01g-an.html
https://www.overclockers.co.uk/evga-clc-240-rgb-all-in-one-water-cooling-240mm-hs-009-ea.html
https://www.overclockers.co.uk/cors...cpu-cooler-240mm-cw-9060016-ww-hs-025-cs.html
I have a few questions first
- Will it fit at the top
- Is the 240mm radiator to big or small
- is the water already in the radiator and does it need replaced after a while or topped up
- Can I fit a bigger radiator in the case if so at the top or some where else
