** Liquid Metal Pro - Back In Stock! **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have just had a fresh shipment of Liquid Metal Pro.
Awesome.
Coollaboratory Liquid Pro Liquid Metal Thermal Paste @ £8.99 inc VAT
Coollaboratory Liquid Pro is the first heat conducting medium, which is worthy of its name. It is the first heat conduction paste that consists of 100% liquid metal alloy. It is liquid at room temperature (like mercury), but it is absolutly nontoxic and has a high moistening ability for several materials. The Coollaboratory Liquid Pro is especially recommend for nickel-plated copper
Coollaboratory Liquid Pro contain no non-metallic additives (like silicone, oxides etc.) at all. It also does not contain any solid particles. Due to these properties, Coollaboratory Liquid Pro surpasses the best high performance heat conducting pastes by a multiple.
Only £8.99 inc VAT.
ORDER NOW
For an afternoon of comedy and insightful enthusiast discussion, Check out this thread full of invaluable customer feedback :)
For anyone that hasn't used this/is scared to use this: it's brilliant.
You use so little with each application, the stuff just spreads and spreads one tube will easily last several builds. But remember to be very careful when using it to not get any where you don't want it.
I am using ultra on my delidded ivy
Unfortunately I've not been able to compare it with anything but temps max out at 52 at a mild 4.6GHz. At 4.9GHz it reached 63
Application really is a breeze and nothing to worry about.
