This stuff, despite being a pain to apply seems awesome,
I was using Gelid OC extreme and also tried MX4, on a de-lidded 3770k, mounting was correct in both instances, full load temps @ 4.8 @ 1.35v were around 80 degrees in prime 95,
Changed to Phobya liquid metal, and changed the compound between the die and heat spreader to liquid medal too, now my full load temps @ the same settings are closer to 50 degrees than 80.
I wondered if i'd simply done a bad job of mounting with the MX4 and Gelid, but each time I took the waterblock off the impression on the TIM was pretty much perfect...
Are any of you guys using it with a W/C setup, if so - what temps are you seeing?
