- 7 Jul 2009
- Newcastle/Aberdeen
Well in casually searching for a better way of powering the world's cars i started thinking - what would be the best substance for it? Obviously not the whole world has access to large quantities of this, but little old water. Distilled, that's Hydrogen and Oxygen. It would be easy to do away with the oxygen altogether, and use the Hydrogen to generate electricity which would eventually power car. But to exist in a liquid state Hydrogen would have to be cooled to −252.87°C and pressurised, something which on it's own it pretty hard to do from water. Besides, we all know what electric cars are like. So my proposition is this, separate the two elements from the water via electrolysis. This would leave you with Hydrogen and Oxygen gas. So to make them into liquids you need to cool them, as well as pressurise the Hydrogen, which would be done first to the Hydrogen using stored electricity in a battery (perhaps trickle charged by a solar panel elsewhere on the vehicle). Here arises the first problem - how do you cool it to −252.87°C? Well, (taking inspiration from CPU cooling here) some form of highly efficient phase change or vapour cooling might come in useful here. Going into specifics later, but Liquid Nitrogen would come in useful here. Can't have everything i suppose... then to pressurise it, which could be done with a piston (in a sort of syringe orientation) at regular intervals, with a certain amount of the cooled Hydrogen. Assuming this all worked correctly, you would then have Liquid Hydrogen. This could be used to power the cooling systems and piston, which would then (hopefully) be powerful enough and have a consistent supply to cool the Oxygen to the required temperate of −182.96 °C. This Liquid Oxygen would then be used (perhaps with a mixture of the Liquid Nitrogen, which is handy when you look at the compound H2O, as i shall explain below) as fuel in a modified Internal Combustion Engine. Since both of these elements in their liquid state can be and are used as main components of rocket fuel, they should have ample (of perhaps over, hence the modified engine) combustibility for our little old automobile.
Thanks for reading (if indeed you did), i just thought i'd run this by you before taking it on as a side project to work out all the specifics. Any problems you see or suggestions you have? So yes, i'm basically asking you to poke holes in it.
Cheers
Cheers
