- 31 Mar 2016
- Moonbase Alpha
Are you trying to say that they all look the same?
They don't even look remotely similar.
They do to me, and all I said I was struck by it, which is a fact that you can't argue with. If you are to read any more into that I would say that is your issue.
I find it a curiosity that two people of apparently similar, less common, backgrounds have wound up with the highest position in two of the most major companies that provide PC components. Nothing more. I just wonder what in their cultural backgrounds seems to have made this more likely.
I suspect they're simply both good at what they do.
It is clear that they are good at what they do.
So why are you still digging? Can't you accept it or do you really want a different answer?
I regret having made this thread. Please consider my impulse to make this thread retracted.
I meant no offence, and my follow up posts were an attempt to explain why I did make the thread.
They look absolutely nothing like each other in any way whatsoever, apart from the fact they both wear glasses.Perhaps you should join them in getting some too!
