List your CPU TEMP, speed, cooling!
Cpu: Amd64 X2 4400 Toledo E6 939
Cpu Speed: 2.695 Ghz
Vcore 1.53? (will update)
Cooling: Scythe Ninja
Room Temp 22.5°C
Idle Temp: 28/29°C core 0, 33/34°C core 1°C
Loaded Temp: 49/50°C core 0, 51/52°C core 1
Not bad considering, mine is lower temp compared to others, those at stock! (mine similar to WC above)
CPU: Intel p4 630 3ghz
CPU Speed: 4.007 ghz
Vcore 1.4375V
Cooling: Arctic cooling freezer 7 pro (overvolted)
Room Temp : 32C
Idle temp : 34C
Load Temp : 48C
CPU: AMD64 4000+
CPU Speed: 3.079ghz
Vcore 1.4
Cooling: Swiftech Watercooling
Room Temp : Not a clue. :p
Idle temp : 36C
Load Temp : 45C
Cpu: Athlon x2 3800
Cpu Speed: 2.4GHZ
Vcore: 1.45v
Cooling: Artice Freezer Pro
Room Temp: 24.2c
Idle Temp: 25-35c
Loaded Temp: 46-50c
Cpu: Intel E6300
Cpu Speed: 3.15GHZ :D
Vcore: 1.325
Cooling: Mini Typhoon
Room Temp: 22c
Idle Temp: 31c
Loaded Temp: 40-42c
Cpu: AMD Opty 165
Cpu Speed: 2.7GHZ
Vcore: 1.4
Cooling: BigTyphoon
Room Temp: 22c
Idle Temp: 36c
Loaded Temp: 45-47c
Cpu Amd64 opty 148 Sandiego core
Cpu Speed 2.65HZ (2Ghz stock)
Vcore 1.4
custom water cooling.
Room Temp 27°C
Idle Temp 32°C - 36°C
Loaded Temp 35°C - 38°C :cool:
CPU: C2D E6400
Cpu Speed: 3.3Ghz
Vcore: 1.42v
Cooling: XSPC water 10/8mm tubing
Room Temp: 22c
Idle Temp: 24c
Loaded Temp: 42-46c
Cpu: opteron 165 CCBBE
Cpu Speed: 2.934ghz
Vcore: 1.44v
Cooling: Gigabyte g cooler pro on minimum
Room Temp: Dunno, about 22 degrees I suppose
Idle Temp: 38 degrees
Loaded Temp: 51 degrees
Cpu: E6700
Cpu Speed: 3.6 Ghz
Vcore:CPU-Z says 1.213 Asus Probe Says 1.47 But I Put It At 1.515
Cooling: Thermaltake Big Typhoon 4 in 1 Heatpipe
Room Temp: No Idea But It's Quite Cool
Idle Temp: 39°c
Loaded Temp: 60°C :eek:
CPU: Pentium D 805
Clock: 3.60ghz
Voltage: Stock
Cooling: Freezer 7 pro (only fan in case :eek: )
Room Temp: 30
Idle Temp: Never Idle / Never off
Load Temp: 60°C max (both cores at 100% Folding for team 10)
Cpu: AMD 3700 San Diego
Cpu Speed: 2.86GHz
Vcore: 1.5v
Cooling: Alphacool Watercooled Setup
Room Temp: 23.3c
Idle Temp: 29c
Loaded Temp: 46 - 50c (Crap case :mad: )
Cpu: AMD X2 4400+ (939)
Cpu Speed: 2.2GHZ
Vcore: 1.36
Cooling: Freezer 64 Pro
Room Temp: 23c
Idle Temp: 36c
Loaded Temp: 44c
CPU A64 4000+ San Diego
CPU Speed 3.0GHz
Vcore 1.5V
Cooling Arctic Cooling Freezer 64 Pro
Idle Temp 35°C - 45°C
Loaded Temp 52°C
Cpu: AMD Athlon 64 3200 + Venice (E6)
Cpu Speed: 2.55Ghz
Vcore: 1.5v
Cooling: Arctic Cooling Freezer 64 Pro
Room Temp: ermm..
Idle Temp: 35-40
Loaded Temp: 43-48
Cpu amd64: 3800 Orleans
Cpu Speed: 2.6GHZ
Vcore: stock
Cooling:stock
Room Temp: 666°C - i live in hell
Idle Temp 41°C - 44°C
Loaded Temp 50°C - 53°C
Cpu - Intel Dual core 805d
Cpu Speed - 3.9Ghz
Vcore - 1.520v
Cooling - Watercooled custom
Room Temp - 25 - 30
Idle Temp - 25oC
Loaded Temp - 39°C -41°C
- its power hungry
