Yup, they are. I saw some Sanyo-branded 2500mAh NiMHs at a well known store recently, £1.99 per pack of 4. I bought several packs. I went back a few days later for some more, they were £5.49 per pack of four .... but a different brand.daz said:I think Nickel Metal Hydride (NiMH) AAs are available, up to around 2500 mAH. Rechargeable too, they should last longer than normal alkaline AAs.
If anyone's interested, Argos are doing Duracell rechargeable AAs on offer atm. 1800s - £3.99 for four, 2500s - £5.99 for four. Very handy for bicycle lights at this time of year.Sequoia said:Yup, they are. I saw some Sanyo-branded 2500mAh NiMHs at a well known store recently, £1.99 per pack of 4. I bought several packs. I went back a few days later for some more, they were £5.49 per pack of four .... but a different brand.
Mohinder said:I've never seen LiPo AAs before, I'm not sure they exist. Saitrix will no doubt know though if he sees this thread.
Look around at on ebay they also have 8x2600mAh for £9.50 on sale.Vertigo1 said:The big advantage of LiIon over NiMH and NiCad is the total lack of any memory effect when recharging. This is obviously important in devices with custom batteries, like phones and PDAs as it can be expensive to replace the battery, but is less of a problem with standard sizes like AA because when the memory effect renders it useless you just buy some more.
AIUI, LiPoly has the advantage that it can be contorted into far more peculiar shapes than can LiIon, which has made it very popular for mobiles and BT headsets.
saitrix said:NiMH also has no memory, its only NiCd that has the problem with memory.
Also Lipo's can take a much higher discharge rate then Li-Ions so for certain things that have large peak currects they can handle it. This made them perfect for rc planes, hense why they are used so much in the hobby. One advantage now is that the latest lipo's can be charged at 2C.
Dandle said:I may be wrong but i was always told that cells themselves dont really suffer with memory effect. Its normally packs of cells getting out of balance that causes loss of capacity(memory) unless they are ageing or have been charged quicker than they should. Li(both types) cells are around 3.6v which would take 3 NiMh or NiCd cells to make the same voltage and can get out of balance pretty easily with fast charging(even more so as the amount of cells in a pack increases). A guy at my work flies model a/c at shows and he still swears by NiCd Sanyo red cells and recons most pro fliers still do due to the current draw they can sustain with modern brushless motors. Although their packs are very carefully matched and charged.
LRK brushless, well thats a different matter.
