My plan (that I came up with yesterday morning) is to have the radiator(s) and pump in the loft and I'm looking at these sort of pumps http://www.theaquariumshop.co.uk/index.php?cPath=469_23 but I wasn't sure how powerful they would need to be to lift the additional water up 1 floor into the loft (from my bedroom). I'm guessing normal PC pumps don't move that much water, but obviously my idea would involve having more water in the system.
er as long as the circuit is a loop back down again, it doesnt need a head pressure of 3m as its just a circulation pump.
Head pressure refers to how high it will lift the water without the aid of mavity pulling down on the other side. ie for a fountain.
As long as the system is sealed so that mavity is acting on the same amount of water on the downside, a pond pump should manage to circulate the water.
Works fine on Koi Pond Filter systems, isnt that hard to seal a system, but you wont get away with just barbs as the weight of water in the system will create a massive pressure at the bottom of the rig!
Haven't lost a drop in mine for months... Compression fittings for the win
