Permabanned
- 11 May 2011
- glasgow
watercooling system consists of 2 x RX240 equipped with fans on push pull, 1 is mounted in the roof and the other at the front. Temps on idle sit at 32 and rise to 58-62 when pushed
Going to substitute the roof radiator to a 360 with push n pull and put a single 120 rad at the rear also on push n pull. Reason being noise of all the fans at present is rather noisy so was think more rad space with fans on controller running at low speed.
Question is the pump im running at present is the xspc dual bay 750 rev2 pump which puts out approx 750 LPH, is this pump going to tolerate the additional radiators or will I have to upgrade to a bigger pump. ( I have a mcp650 lying around which pushes out 1200LPH)
any assistance much appreciated
