Hi Guys,
Starting to piece together a new build but quite seriously am finding the biggest uncertainty and sticking point to be which case to have?!
Can someone help point me in the right direction please? Budget for case is up to £120 ish, needs to be able to handle a high-spec inside with enough room for either water cooling or traditional method (as i've not decided). Needs to be un-plastic and have good build quality and most important, needs to be reasonably quiet if not very quiet!
Would also be a bonus if the case was aesthetically pleasing on the eye too!!!
Any help greatly appreciated.
), but the V1000B+ II is on a different planet. The metal is at least twice as thick and the retaining mechanism is a work of art. All the Lian Li's have beautifully tasteful design and the wide range of optional extras fit any of the models in the range so you can upgrade them if you went from a PC7B+ II to a V1000B+ II you could just move the drive stealthing plates across.
