Little bit of help needed please
30 May 2004
Uk
Hi
I'm experiencing a pretty strange problem and I think it's the motherboard. It is an Asus M4A79T and it randomly refuses to boot. It will power up the fans (fans stay on full power) but get no post screen. I have tested my ram and both are ok but weirdly the only way to get it to boot again is to remove and reseat the ram. It also varies from which stick of ram it will boot with.
Anyone any ideas on what could be causing it ir is it likely to be the motherboard as I suspect?
Cheers
Could be a loose connection, or possibly dust in connections, try reseating all components and giving connections a blow out with compressed air, or use a hoover
Failing that then yes its likely to be mobo
