Little bit of help please
Caporegime
6 Dec 2005
Birmingham
The program can't start because MSVCR100_CLR0400.dll is missing from your computer. Try reinstalling the program to fix this problem
If anyone would be kind enough to copy their's and email me it to my trust email that would be brilliant. I'm using W7 64bit so I'm guessing you'll have to have the same OS. I have tried reinstalling by the way. :p
The file should be in here.
Code:
C:\Windows\System32
Thank you! :)
No problems mate. :) I saw no-one had replied here so assumed you'd not been sent anything. Then when you said W7 x64 I thought I'll have that file. It's easy to send you the file so why not? :)
