Little bit of virgin superhub help please
21 Oct 2002
UK
Hi all,
I have had virgin cable for about 5 years. I have always used just a modem from virgin plugged into my WRT54GL running tomato firmware.
I have upgraded my bb today and they have installed a superhub. The wireless isn't as good from this as my router so what I want to do is route the internet through the superhub to my router.
Can someone please let me know how to do this.
Also, I can;t seem to access the settings of the hub. IPconfig says my default gateway is 192.168.0.1 but putting it into my browser just times out. I can ping the connection and it all works ok as I am posting this while connected.
Anyone have any idea on why this would be?
Thanks
Thanks KIA, a restart did it, now working in modem mode, thanks!
Does anyone know how long it takes for the connection to change? My connection is currently 10mb but has been upgraded to 60mb.
As soon as the guy came and fitted the superhub it should have changed to 60mbps
some fault then surely...
call customer services virgin and ask to confirm there speeds... maybe something not quite right there.
