I have a Gigabyte P55A-UD3 which has capacitors which buzz under full load when the volts are around 1.25-1.4, the buzzing getting more severe as the volts go up, and I sent a couple of webnotes about it and it is indeed a fault. However, I'm very worried it will come back as 'No Fault Found' as it is a problem which only appears under full load, and you have to be in quite a quiet enviroment to hear it AND the volts have to be at a certain level. Also, the noise only really appears after you pass 1.2v when running at stock speeds. Because of this I'm dubious about returning it. Could anyone offer some help/guidance? Possibly someone who works for OCUK testing faulty stuff?
Thanks
Thanks
