Little cabling issues.
25 May 2013
Kent.
As you know on some motherboards (may be just the older ones) they have little one wire connection slots for POWER, LED +/- RESET etc, and can be quite fiddly and look untidy. Upon browsing various tech sites I have seen builds where they do not show at all, and it is all very tide and professional looking.
Is this only on certain motherboards? Also for the front panel audio or something as well I think it is.
EDIT: Woops, forgot to post in Mobo section, sorry.
Can't atm, having trouble opening Google, and phone is away for repair. I'll try and describe it: When the PC is upright, to the right lower side of the Motherboard is a set of 8-10 little slots, one for each Power button, reset switches and led's which are connected by a black attachment on the end into the individual pins. Think it's just called a header.
Yeah, I know what you mean :) It's possible for show machines they're disconnected for the pictures, some people cut the AC97 or whatever it is off and just plug in the HDAUDIO
Ah right, I'll have a look for Mobo's on here see if I can find any that makes me PC a little tidier, thanks for the help!
Can be locked now.
