- 23 Aug 2007
- Rothesay
As some of you may be aware i recently purchased a set of Beyer-dynamics DT770 250 ohm Headphones and also bought a little dot II to drive them to thier full potential.
Over the past few days when turning on the Tube amp im getting an annouying buzzing noise from the headphones with a little playing about with the 6.3mm plug removing and replacing it into the socket on the amp i can usually get the buzzing to dissappear.
I have tested the headphones directly into the Asus Xonar U5 external sound card i have and the buzzing is not present. i have also tested out my older Razor Tiamat 2.2 Headset in the amp and the buzzing is present there also.
The only theory i can summise is there is an intermetent issue with the Amp but what is causing it im not aware of.
i'm putting it out to you ladies and Gents here to theorize what could be causing the issue and if it is/should be possible for my to resolve without having to send the unit back for a repair/replacment as for me living on an island this will be a costly and time consuming excersie.
