Little extra to go with Creative Iroar
5 Aug 2013
Evening.
I have a creative Iroar plugged wired into a Maximus Hero IX
For general use i really like it however I wouldn't mind getting something to go with it like a sub or something.
Question is, how would I get this to work? is it even possible?
Any help appreciated
Stret
That's your best option, as the iroar has no output for any other subwoofer.
The only other possible way would be to use the auxiliary input and use splitter coming from the PC (which I assume you have the iroar connected to) on-board audio or sound card. You'd have to set the volumes independently and control the volume with Windows.
That will only work using the auxiliary input though, not USB or Bluetooth.
That's a shame as its pretty good this little speaker.
So next question is... good set of speakers that come with a sub :D
