Little Gaming Box
10 Mar 2009
Hello One and All.
Looking to build a SFF system for general web use and some gameing. Basically a "Steam Box" type idea for my lounge.
Games will be played at 1080p
Not looking for for high settings.
Would prefer low noise and a small footprint over preformance.
Game examples
Sonic Generations
Various Lego games
Occasionally, World of warcraft
Is what im thinking.
Budget is around the £450 mark.
Looking for suggestions and case ideas.
Many thanks.
Personally I'd go Sugo SG05 300W as it's a bit smaller.
Or if you want to go TINY (and you can cool the APU) try a Streamcom FC1 EVO and the 150W PicoPSU they do. I think you'd be OK power-wise (might have to undervolt a touch), but you'd may need a slightly better cooler than the stock one.
Beautiful tiny thing though!
They do a version of that Lian Li with a slim optical drive slot - shaves a bit more off the height if you don't plan on putting in an optical drive.
Enjoy the build!
dont buy Asrock !!!
there are numerous cases when it set on fire by itself!!!
am considering MSI myself or asrock with A85
