Little help folks?
16 Aug 2005
Ok heres the problem.
I have a SATA hdd, the little black piece of plastic that holds the sata cable in place has snapped off leaving the 7 metal prongs coming out of the disk. I would like to get the data off the disk and copy it onto a spare. What is going to be the easiest way to do this? I don't know where the little piece of plastic is and if i simple slide the cable onto the pins, the PC doesnt detect it in the BIOS (I suspect the piece of plastic acts as something to hold the pins against the SATA cable).
Ideas? Suggestions? Any comments would be appreciated.
Mike
Hi Stulid,
Thanks for taking an interest! Here is the hdd
fold some paper to the same thickness as the missing plastic bit and use it to keep the contact with the cable plugged in.
yeah, but shove it into the actual cable end, this should provide enough pressure against those broken fingers, to the bits inside the cable end.
Weather this will help at all. do you a old sata cable chop the end of and see if can wrap the cables around the terminals.
As always stulid you have come up with the goods. I tried cutting up a train ticket and wedging it into the space on the hdd where the plastic thing snapped off from. Impossible! I tried wedging same ticket into the end of the sata cable and even as we speak 750 gig of stuff is being copied off of the old disk and onto the new :)
Might try and glue it on and continue to use the disk - might use it as a steam drive as the worst that happens is that I have to redownload my games.
