Hi,
Started using flight sim 2004 only got 512 mb ram so i need more, been to ****** to check out that they say and this is what i got
Maximum Memory Capacity: 3072MB
Currently Installed Memory: 512 MB
Available Memory Slots: 2
Number of Banks: 3
Dual Channel Support: No
CPU Manufacturer: AuthenticAMD
CPU Family: AMD Athlon(TM) XP 2500+ Model 10, Stepping 0
CPU Speed: 1833 MHz
When using DDR400 (PC3200) the system supports a maximum of 2 banks of memory, when using DDR333 (PC2700) the system supports a maximum of 4 banks of memory. A single DIMM will either have 1 or 2 banks of memory.
and i think i got the DDR PC2700 type.
Whats it worth me buying in your opinions, should i just do a cheep up grade to 1gig and save up for a whole new system or go for a 2.5 -3 gig upgrade?
TIA
Number of Banks: 3
CPU Speed: 1833 MHz
TIA
