Hello all,
I would like to ask for a simple (but still good looking) custom h2o loop. The case is Corsair 540 (and both 5.25" bays are used) with Z97 MPower Max AC board (so it has waterblock included!) and i5 4670 (Haswell).
All I need is 360 Radiator that has some of those fins/screws protectors on it (thick alphacool would be best if it has one of those protectors). Together with reservoir that will stand somewhere inside the case (by the window) as 5.25" bays are used, and anyways they're oriented to the side. Some pump to handle it, fittings (those nice screwing in ones, don't want to zip tie them) and CPU block.
I am happy to get coolant and hose myself, so no need for that, though if OC'ers has some compatible hose in stock then why not add it too?
I will get GPU waterblock in January/Feb (when I get new card) as I currently plan to sell my gtx770.
Cost: no more than 170GBP. I looked at H2O kits but reservoir is usually drive bay so I'd have to buy one anyway..
Thanks for any suggestions.
