Little help with case wiring (Corsair500r)
12 May 2012
Hi
Sorry if this is in the wrong section but its partly to do with the case :P (feel free to move where it needs to be)
Basically, i have the Corsair 500R case, i have have plugged in and working but the Fan speed control and LED button dont seem to be working, can anyone help with where these are ment to plug in to?
Thanks
Can you please fix your sig, the maximum allowed number of lines is 4
Thats the mod duty out the way.
No onto your issue.
Do you have any left over cables coming from the top front panel that are not hooked up?
I ask because usually you feed power into a fan controller from a PSU connector and then this splits it up between the fans connected, have you given the fan controller a power source?
Hi, yea will do summit with it at a later date prob haha
the only cable not plugged in is one labeled 1394 (i think :P)
all the fans seem to be connected, and they all work at 1 speed, the power cable coming from the top also has a power feed.
would be nice if the case instructions came with an idea of what each wire did haha
So, You have the cables from the Fan speed control and LED plugged in ? I know on my HAF X there is a small 2 pin male connector from the front fan into a 2 pin female connector for the LED, Have a look and see if there is one on that case.
