little help with L.A Noire frame rate at 24fps
13 Apr 2009
Herefordshire
Hey guys just downloaded and installed l.a noire on the new steam deal.
Now i know that the game is framerate capped at 30fps to give the game that "film" feel, the only odd thing with mine is that its capped at 24fps and i get a massive amount of input lag with mouse, now i do know i have a 3D monitor (passive) LG DM2780D but i have not enabled 3D anywhere from what i can see.
Another note is as i was playing the game or monitor (cant tell) would go blank and switch to allowing 30fps (as if it was exiting 3d mode) but then 5 seconds later it would go blank again and start at 24fps.
I cant tell what the issue is, any help guys?
Also no input lag when running at 30fps
Specs
| i7 2600k @ 4.6ghz(1.328v) Noctua NH-D14| Asrock z68 Extreme4 | 8GB of Kingston HyperX Ram@1600 | Crossfire 2 x 5850 | Viewsonic va2213w | WD 1TB| xfx 750w modular|
seem too of fixed it.
you have to change the resolution everytime you go into the game so it refreshes itself.
still at 30fps which im not fussed with.
