Little help with sons PC
20 Apr 2008
West Midlands
Basically he has a Dell Optiplex 745 which he uses for school work and day to day internet browsing. But he is also now getting into PC gaming.
His PC isn't upto scratch for much decent games etc and would like to upgrade his PC so he can play some.
Now i want to do this as cheap as possible and wondered if you could people could point me in a cheap direction for doing this or a way to upgrade his current PC
any help would be appreciated :cool:
i'm unsure of the PSU without having a proper look but this is what he has so far
obviously the GC needs upgrading and also the ram but i'm wondering if it's worth trying to sort the motherboard out too?
also budget isn't a great deal. £100 - £150
I don't think you should expect much gaming from a Dell PC to be honest , even their "Gaming" PCs are crap ...i had one , even put a new 600W PSU in it too ....complete wast of money :D....you would do better ( if you can ) to maybe save some money and get a proper mobo a proper PSU and case too :)
Take a look around for the cheapest 1155 board you can find (it will usually be a H61). With that grab a cheap 1155 chip (an i3 would be nice but probably a bit too much, the G8xx intel chips are 1155 and "ok".) When Haswell comes there's going to be a lot of "old" 1155 chips on the market/bay to upgrade again to something a bit more rounded chip wise.
I did for a friend:
H61 + G820
8GB Ram
GTX460
Which has made a perfectly ok little gaming machine for £160. He already had case and drives etc. A lot of it was MM stuff etc ofc.
If he is going to do that then he may as well start from scratch.
Looking at the system I agree with Idleman 2x2gb ram and a graphics card.
I'm gonna assume the power supply isn't gonna be great so without it's specific spec the following card is what I'd suggest as it don't require additional power connectors.
HD 7750 £83.99
http://www.overclockers.co.uk/showproduct.php?prodid=GX-072-HS
This is by far the best card in it's class and really anything faster would be wasted on an E6400 anyway. :)
For the ram I'd recommend looking for 4 Gb on the MM or other well know 2nd hand sites.
