Little help with spec
I'm surprised :p
All components work well together. Decent brand SSD. Strong CPU that will still be a great performer for years to come. Even if the entire thing is about 20x more than you need :D
Although, you won't need RAM with a speed higher than 1600MHz. Speed for i5 is limited to 1333MHz 'naturally' - only reason to get 1600MHz would be if overclocking to give you some headroom.
For that reason, I'd get this instead.
4GB will be more than enough for you, and it lets you either have £40 spare, or spend it on some flashy LEDs/fans to add a unique touch to your case :)
(N.B. If you must get 8GB, then personally I would get a Geil stuff).
I've got 6 red led fans already and loads of blind stuff.
I just want to upgrade it. Because I can get some money for my old CPU,RAM and mobo.
And I've had my money's worth.
What do you reakon to the board. Should I go for a better brand?
Patriot PS-100 64GB 2.5" SATA-II Solid State Hard Drive £81.70
(£68.08) £81.70
MSI 870A-G54 AMD 870 (Socket AM3) DDR3 Motherboard £79.64
(£66.37) £79.64
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £76.79
(£63.99) £76.79
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £35.99
(£29.99) £35.99
Sub Total : £228.43
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00
VAT is being charged at 20.00% VAT : £47.49
Total : £284.92
Don't forget OcUK's VAT decrease, letting you get it for: £268.41
