- 26 Jan 2005
- Newcastle, UK
Hey all,
Just wondering if anyone can help me with this little form problem I have.
www.scottjs.net/test.htm
If you type in box 1 it will copy the text into box 2 as you're writing it which is what I need it to do, but it is always one character behind and I don't know how else to do it. So if I type a character, the char won't print in the other box until I press another key.
Is there another way Ican do this so when I type the first char it shows the first char in the other box straight away?
Thanks,
Scott.
Thanks,
Scott.
