Little mouse issue
25 Nov 2011
The KOP
Hello am using a Logitech G500 with boogie Bug mouse mat. Now the mouse works great if am just swiping about, but the issue comes when I need to do fine small movement, like lining up a shot (this happens on all games) it feels like I need to force the mouse for it to pick up the movement.
Am wondering if its a setting problem? Anyone understand what I mean, and if so is my mouse broke or is it just a setting I over looked.
Logitech settings
DPI 1200, 1600, (2000) < what I use
Speed 5
Acceleration 0
Report Rate 1000
Use OS native drivers disabled
Angle snapping disabled
thanks
Sounds like mouse acceleration in Windows settings to me.
*Enhance pointer precision*, turn it off under mouse properties.
Can you turn off Vsync in the graphics options? Sometimes that causes this lag for others.
Now that you say that I do play with vsync on all games apart from metro because couldn't get it working.
Everything else works superb, but once I try and fine tune a shot, its hard for me to do so am just wondering if its because am new to PC gaming and thats the effect a playstation pad had on me :confused: LOL
Aha, it could be.
Well, turn Vsync off and see what happens. If not, it could be that you need to get used to it.
You're welcome.
