I've just overclocked my main rig a little, it's not much (AMD Athlon 64 3200+ ClawHammer) from 2000mhz to 2420mhz.
It's really annoying me because the board will hit 300 FSB fine and I can get into windows at 300 fsb with a divider on the memory to keep it within it's stock speed.
The problem is that I can't put the CPU multiplier back up to 10x
I have to keep it around 8x (300*8=2400). At 9 or 10 it gets stuck during the POST.
Simply put I can't seem to get it up to 2500 mhz or further no matter what combination of FSB, Divider and Multiplier I use
I've got maximum voltage through CPU, RAM and Chipset.
CPU stock voltage is 1.5. The motherboard is set to 1.7 volts and it's currently measuring 1.79 - 1.8.
Memory is upped from 2.6 - 2.8 volts and chipset has an extra 0.3 volts.
I ran a Prime Small FFT Torture Test for 27minutes with no errors, though the Power/Aux temp reported in SiSoftware Sandra Lite was 47 - 57C
