I "think"this is the correct section of the forums, soooo
I have created a longish (240 slides) powerpoint presentation (even managed to get it to autorun from a cd without the user having to install powerpoint viewer)
To make it feel a bit nicer, I have a cd track converted to mp3 to try and play as background
Followed the instructions to insert the sound file, then set the options so that it should play then stop after 240 slides
but all i am getting is a music/speaker icon on the first slide and no sound at all.
I have checked the mp3 file and it plays on its own.
would any body have any idea at all please.
thanks
thanks
