I always thought it was best not to use them since a lot of the mounting points on the mobo are grounds and need a good connection to the case or am I just plain wrong (again)?![]()
The motherboard is also grounded thru the black cables going to the PSU, so you could even use a wood case if you wanted too! Basically, use those washers and don't worry about grounding.I always thought it was best not to use them since a lot of the mounting points on the mobo are grounds and need a good connection to the case or am I just plain wrong (again)?![]()
