little teaser
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
^I was wondering the same thing, not keen on the fixed "tower" design of drive cages. If the middle is removable at least then it's good for me.
Yes - front centre panel is removable on front panel.
Yes - all HDD cages are removable, six simple screws to remove both cages.
Photo I took myself - not a professional photographer. Note the runners at the bottom of the case, you get two adjustable brackets to fit a pump/res in there :)
