Live for speed question.
12 Jun 2004
Exeter
Hi all,
I have Live for Speed S2 and when I save a replay, I want to be able to skip some of the replay to make it shorter.
If I am in a server for 30 mins and something at the end happeneds and I want to see it, I would have to watch through the whole 30 mins before I can see the incident.
Is there a program I can download that would let me skip some of the replay and see just the part I want to?
LFS saves the files as .mpr if that helps?
Cheers.
Memphis said:
How about just using the F1-F4 keys to speed it up?
Ahh, thanks. I didn't realise that was possible. But I would really like to save just the interesting bit and send the file to a friend - otherwise it could be a 10MB+ file when it only needs to be about 300KB.
Either zip up the replay file or fraps the bit you're interested in.
Improved replay rewinding/forwarding etc is expected in a patch sooner or later though.
