Live Messenger "glitch"
4 Sep 2003
Anyone experienced this?
Yes I have tried re-installing :(
Have you tried a repair of WLM? I just had to do this on mine and the installer detected WLM was already installed so it offered me a Repair feature.
Try removing the Apatch settings, then remove WLM. Then reinstall WLM and Apatch.
I found it was to do with changing the colour of the app.
When i set it back to default colour scheme it vanished.
Have had this bug for quite some time, in both vista and xp :(
I was just about to post this exact glitch.
I have the same problem in both Vista and XP. Change the colour to default and it'll be fine. Some colours work, others don't.
