- 25 Jul 2009
- England
Hello.
I can run GRID: Autosport fine on high settings when im not streaming. However when I stream it seems to lag a lot and buffer even though I get 15-20mbps. My bitrate is set to 2000 is obs which should be high enough.
The only other thing could be my pc spec
AMD Phenom II x 4 965 @ 3.8GHz (overclocked today from 3.4GHz).
8GB RAM
GTX460
I was pretty sure video cards didn't effect streaming but I did see on youtube someone said there stream used to be bad until they upgraded there video card?
Any advice, what I need to do to sort it as its definitely not the upload speed?
Thanks
8GB RAM
GTX460
Thanks
