live streams help
18 Oct 2002
Manchester
simple probably but is there a way of recording live streams using WMP V.10.00
I want to save a tune to my Hard drive so I can translate the lyrics from Russian to English.
If you can help I would appreicate it
Audacity
Free Sound Editor.
Install, change preferences to Stereo, select "Wave Out Mix" from the input drop down in the toolbar. Hit record and play your track in Media Player, streamed from web etc.
Voila - Stero recording, works on pretty much any audio stream... :D
