- 30 Sep 2005
Grrrr,
I've been reading up on many forum posts and it seems that the lower LLC you use, the higher the idle volts are?
If this is the case, then something is very wrong with my motherboard as going from 0% LLC to 100% makes no difference to my idle volts.
My issue isn't with volts under stress, but the dreaded 124 BSOD when idling. My volts are dropping too low. Sat on the desktop I can see my volts drop to 0.800v, and probably lower when the blue screen shows up
any tips for a noob?
Thanks!!
Thanks!!
seems to go down to about 0.869v at Idle which I think is normal at x16. When stressed it goes to about 1.360v about low 70s after a good session on IBT
