LN2 overclocking system?
27 Sep 2009
Hi all,
Can Overclockers pre-build a gaming PC with liquid nitrogen overclocking? It would be great to get a stable 5GHZ build!
how would that work? ln2 has to be applied to the pot repeatedly through out even just a half hour bench. Do you have access to ln2? If you know what your doing to use ln2 you really dont need ocuk to pre build you a system, if you dont know what your doing, you really shouldnt be ****ing about with this stuff
you may well get a stable system with LN2 but good luck using it day to day.
a decent water loop would be more than enough cooling for 5ghz but you could have the best w/c setup around but it doesnt mean your gonna get 5ghz.
If you put liquid nitrogen in a close loop, it will boil and "explode" like water over 100C. (but with the nitrogen it will happen with lower temp)
Look into thermoelectrics or phase change for 24/7 operation, not liquid nitrogen.
Overclockers are unlikely to build a computer using those for you either, but have sold individual phase change units in the past.
It seems a reasonable premise that if you cannot handle the trivial task of plugging components into a motherboard, you won't fare well with below ambient cooling. Weirdly the blog in your sig appears to show you putting together a DIY SAN in a 4U chassis.
This thread made me laugh.
Im pretty sure 8 Pack systems will be out soon featuring 5Ghz under water and possibly under air (it is possible).
24/7 LN2 is a stupid idea with present technology.. Have a go yourself if you want.
I suppose it is possible - provided you have a plant extracting the N2 from the air, compressing it to a liquid, which runs through a heat exchanger to get the temperature back down, before pouring it into a pot - but it just looks like a bonkers way to run an open loop phase change system :)
I run a 5Ghz 3770k with water absolutely no problem's. LN2 rigs are for benching and pushing systems well beyond their capable limits for competitive and benchmarking reasons this is not a day to day thing.
