load balancing routers/switch
233
233
21 Nov 2004
Wishaw
quick Q for some of the more knowledgeable types.
we have 2 fibre connections in the office and have added a vm connection for redundancy. thinking that if bt goes down we would loose both fibre connections but VM is a different network so gives us a backup.
is there a router/switch that will let us make full use of all 3 connections when everything's working rather than having a connection sitting idle doing nothing.
the reason for the need to backup is we are a taxi company and our entire dispatch is cloud based. no internet no dispatch. (and yes we have a 4g wifi box plugged in and charged and a couple of laptops available in case of power cuts too :)
so basically
80meg Fibre. 80 meg Fibre. 350meg Virgin
Magic box of inter web merging
233s office network
Having both fibre links now seems unnecessary.
With the 3220 you’ll need a couple of VDSL modems (cheap enough to get).
If you drop back to a single fibre link you could use a 2862 and also connect the 4G as failover.
How handy are you with networking and how much is price a factor? You could buy a mini PC with quad NICs and use pfSense for less but it won’t be as user friendly or come with manufacturer support like the Draytek. An option though.
